2" level and 37s??
so i got to wondering guys.....woud 37s fit with a 2" level up front? if so im gonna go with 37s and really fill the wheel well out. I could always add another inch up front anyway, as it still sits lower than the rear. 37s would look so BA if i could make em work with little to no modification
barely depends on offset i had a set odd cooper stt 37/12.5/17 on my 94 dodge a few years ago and it was tight and rubbed when i turned and i had a fairly decent offset i couldnt tell ya what it was id talk to a tire shop and ask them it can be done no doubt but its got to be the right combination
now that i think i did have to notch the fener a tad for when i turned also
Last edited by 94cummins12v; Mar 25, 2012 at 10:26 AM. Reason: Automerged Doublepost
they may fit a tire shop would be able tell you more may not go with a 12.5 wire tire maybe a tad narrower im not an expert on tires so i dont know the different widths available on different brands
Dodge Ram Specifications
1994-2002 2500 2WD/4WD Steel Wheels:
Lug Pattern - 8 on 6.5", 9/16" bolt
Rim Size - 16x6.5"
Offset - 4.75"
There is your factory rim size. Not too sure what you will need to fit that big boot, but a tire shop will for sure.
Rim Size - 16x6.5"
Offset - 4.75"
