Tubo boot blew off
Old Mar 24, 2012 | 07:17 PM
fixorepair's Avatar
Default Tubo boot blew off
Turbo boot blew off on my way to Terra Haute In and blew oil all over the engine this weekend now the truck does not want to start have cam pos error, ICP error pulling my hair out any ideas.
Old Mar 24, 2012 | 07:19 PM
bismic1's Avatar
Try starting it w/ ICP connector removed.
Old Mar 24, 2012 | 07:31 PM
mysterync's Avatar
I can say I know the guys at
Scheid terra haute and I assure you they can help you but if your not close.enough that wont help . You have a scan tool you can use?
Sent from my DROID BIONIC using Tapatalk
Old Mar 26, 2012 | 07:36 AM
Mdub707's Avatar
Did you reattach the boot? The oil is just from the crankcase vent, since it vents into the intake right in front of the turbo, not a big deal. Clean the boot up really well and reinstall, it should be fine.
The cam position sensor is probably just being falsely thrown from trying to crank it. Why did the truck shut off? We need a lot more info here about how this went down. Did the truck shut off or did you shut it off and then it wouldn't restart? The boot blowing off would have nothing to do with the ICP, chances are you had other issues going on and the boot blowing off is completely separate.
Paul08
Ford Powerstroke 08-10 6.4L
May 9, 2021 11:01 AM
