FASS Location Question.
Old Feb 5, 2008 | 12:06 PM
Nitelord's Avatar
Default FASS Location Question.
Where are you guys/gals mounting the FASS system?
I should have mine this week (Thanks to Lukesdiesel), and I was looking for your input as to where to mount it...
Old Feb 8, 2008 | 08:06 AM
steved's Avatar
The instructions will have you mounting it under the front driver's corner of the bed...
I know I have read of guys mounting them in other places, in the bed is one that comes to mind.
steved
Old Feb 8, 2008 | 08:16 AM
Nitelord's Avatar
Thanks for the reply. I'll probably keep it out of the bed due to running a cover most of the year. I'm trying to figure out whether closer to the tank or closer to the engine is better. This would only make a difference, if the pump pulled better than pushed, or pushed better than pulled.
Does it even matter?
Old Feb 8, 2008 | 08:19 AM
steved's Avatar
Since the manufacturer's mounting bracket places it back by the tank, and on the frame, I don't think you could place it much better.
Any lower, and it'd be clipping every tar strip.
Old Feb 8, 2008 | 09:12 AM
Wyatt Earp's Avatar
As it is intended to be a pusher pump you want it as close to and as low to the tank as possible to gain the correct hydrology head on the line. Move the pump above the tank and under the hood for example and it won't act much better than the OEM version.
It is almost impossible but ideally you want the pump 100% below the tank and in line with the injection pump.
Old Feb 8, 2008 | 09:15 AM
Nitelord's Avatar
Just what I needed. Thanks.
Old Feb 8, 2008 | 11:31 AM
Wyatt Earp's Avatar
no worries
Old Feb 8, 2008 | 11:39 AM
STROKER400's Avatar
It mounts at the frame right near the tank on the out side and my friends we did the other week was some what simple. And it does not hang below at all where it could get damaged.
Old Feb 8, 2008 | 12:18 PM
Wyatt Earp's Avatar
Correct. The design ideal location of the pump is not real life applicable. Mounting it high on the frame rail will result in no drop but not 100% efficiency is all. Only about 97% where OEM is closer to 60%.
JoeyMiR
9
Feb 3, 2018 10:05 PM
Aug 13, 2015 10:10 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
jdepuy618
For Sale
Dec 21, 2014 05:28 PM
Nov 7, 2014 05:40 PM
