how do i cool my egt??
Old Mar 23, 2012 | 02:10 PM
cummins3500's Avatar
Default how do i cool my egt??
I have a 96 12v and bought a set of 370s and the egt sky's I have stock Turbo w banks waste gate but Idk how to get them down...... mods are afc springs 4k gov. 370s big head waste gate boost elbow 5 in exhaust HELP
Old Mar 23, 2012 | 04:50 PM
daveO's Avatar
Those 370's kill your EGTs unfortunately. They're not the correct spray pattern for our motors.
That being said, there are still things you might be able to do. An aftermarket exhaust and BHAF would help some.
What are you seeing in the way of EGTs?
Old Mar 23, 2012 | 05:13 PM
turbo2332's Avatar
how hot is sky? run your turbo at 35psi with a good intake as mentioned take some rack out of the pump, what size plate you your run?
Old Mar 23, 2012 | 08:27 PM
I have a 5 in exhaust I have 100 plate and I had the plate all the way forward w the afc all the way forward and it hit 1400 degrees should I put stock plate back in?? Until I get my compound Turbo...
Old Mar 23, 2012 | 08:40 PM
daveO's Avatar
1400 isn't terrible if you don't keep it over 1200 for very long. Before my new turbo, I buried my 2000* pyro once or twice for several seconds. If you're worried about it, slide your plate back a little bit.
Old Mar 23, 2012 | 08:44 PM
I did slide it back but egt still goes right up... and on highway I'm around 800 to 1000 degrees..
Old Mar 23, 2012 | 09:02 PM
monster12valve's Avatar
need air! unfortunetly you get what you pay for when it comes to injectors.
Old Mar 25, 2012 | 10:07 AM
Would a d tech 62 or 64 help lower them??
Old Mar 25, 2012 | 10:10 AM
94cummins12v's Avatar
yes i was running 370s with a super 62/71/14 and loved it now im running sdx 5x.012 and a super 64/71/14 becuase the 370s only lasted 2 years
Old Mar 25, 2012 | 11:08 AM
daveO's Avatar
Yeah, a turbo would def help with your peak egts
