loses power ? app
Old Mar 22, 2012 | 08:01 PM
jshel's Avatar
Sad loses power ? app
Will run ok for awhile then will lose power. After I turn off the switch will sometimes be ok for awhile, sometimes will be the same. Mech said might have app problems.
Old Mar 24, 2012 | 12:47 AM
2004LB7's Avatar
app problems ???
any CEL?
could be fuel filter, when was the last time it was changed?
Old Mar 24, 2012 | 07:53 PM
jshel's Avatar
Default changed fuel filter the first time in did this 5 days ago.
Have been getting code P0207 # seven fuel injector open or shorted. Would it run normal if the fuel injector was bad? I ran it 3 miles up to 55 mph and ran great. I did fill the fuel filter with c foam right before. ???
Old Mar 25, 2012 | 11:37 PM
2004LB7's Avatar
are you sure this is not an LLY? they have injector harness problems. typically its #2 and #7.
if yes, then inspect the harness for rubbing through and repair any found.
Old Mar 26, 2012 | 09:13 PM
jshel's Avatar
Default LB7 or LLY?
I don't know how to tell the difference, but I'am going to check the wiring harness for sure. Will let you know. Thanks
Old Mar 27, 2012 | 12:36 AM
2004LB7's Avatar
check the valve covers. LB7 has only fuel lines going into it on the top, with the LLY the valve covers are cut out for the injectors
LB7 is on top, LLY is on bottom
also you may want to do the "Ice Pick" trick if it is an LLY
Old Mar 30, 2012 | 09:09 PM
jshel's Avatar
Default lly
I do have a lly. what is the ice pick trick?
Old Mar 31, 2012 | 12:23 AM
2004LB7's Avatar
injectors #2 & #7 have connection issues. using an ice pick put a dimple in the connectors to provide a more positive connection
The ice pick trick - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Old Apr 2, 2012 | 07:34 PM
jshel's Avatar
Default ice pick
figured out the ice pick. hasn't fixed the problem, mech said I need a new harness. going to let him do it for $540.00 includes the diag he did. I heard that the harness is $250.00.
Mech has a good reputation will give him a try, tired of not having my truck. thanks all
Old Apr 2, 2012 | 07:40 PM
2004LB7's Avatar
sounds good.
FYI - most of the "rub throughs" are at the altanator where the harness rubs on a sharp bracket corner. did you check there?
