drive pressure
Old Mar 22, 2012 | 02:34 PM
cumminskid92's Avatar
Default drive pressure
Ok guys I should probably know this but I dont. What exactly is drive pressure when you are talking about turbos. Also how much is too much or too little.
Old Mar 22, 2012 | 08:15 PM
turbo2332's Avatar
drive pressure is the pressure in the exhaust manifold that is driving the turbine wheel. i cant say what to much is but blocking off wastegates and such creates very high pressures that destroy turbos.
Old Mar 22, 2012 | 10:29 PM
tower_ofpower's Avatar
By destroying he means over-speeds and the turbo comes apart or surges with a quick snap of the throttle then twists the shaft off. The pressure a lone doesn't destroy it, the forces created by pressures do just clarifying. I've heard once that if you can get drive pressures lower than boost pressure you have a VERY sweet set-up and it doesn't happen with single turbo set ups; higher possibility with compounds. Efficiency is the name of the game.
Old Mar 23, 2012 | 05:59 AM
Oh ok that makes sense. Thanks a lot for the info
robbyS
Apr 16, 2015 02:22 PM
CoyoteKiller
Mar 29, 2015 07:11 PM
MAC4232
Jan 28, 2015 01:46 PM
veggyoilkid
Nov 10, 2014 12:39 PM
GreenDieselF
Oct 20, 2014 02:05 PM
