Mack plug ?
Old Mar 21, 2012 | 04:20 PM
SCHMITTY's Avatar
Default Mack plug ?
I was just reading diesel power mag's tripple threat build with the 1300.00 Garmon kit. Anyhow they wrote that it is easier to install the rack plug while the timing cover is off. Since I will be tabbing my kdp this weekend I was wondering if I should Install the plug while it is apart. Do you guys think it is worth it on a fairly stock truck accept for the free mods in my sig? Thanks
Or shimming the current plug with a washer?
Old Mar 21, 2012 | 05:23 PM
Sudia247's Avatar
Don't shim the plug, buy the 2095 Mack Plug, they are only about $12. The only reason it is easier with the timing cover off is because you can loosen the Fuel Pump easier to push it back far enough to swap the plugs. You could always cut the timing case, Ive seen some people do it. Where they dremel the case away til it opens up to that larger area. It won't hurt it, it just doesn't look as clean.
Old Mar 21, 2012 | 07:34 PM
turbo2332's Avatar
i dremeled my case. the rack plug allows for 2mm more rack travel. the benefits of the plug are only noticed at WOT
Old Mar 21, 2012 | 11:48 PM
SCHMITTY's Avatar
I ended up calling a diesel shop looking for a plug and the guy there said he did not have any plugs but he would bench my pump for 150.00 to check and make sure everything was working right and that he would tune it for the original 150.00 plus 150.00 in parts. He said 300 or 400 hp tune. Does that sound right or is he selling me bs ?
Old Mar 22, 2012 | 07:23 AM
turbo2332's Avatar
the plug is a bosch #1 413 462 095-000 i do believe.
Metz1234
Mar 3, 2016 10:20 PM
8ntnofoo
Sep 1, 2015 06:52 PM
ajwright64
Feb 4, 2015 09:36 PM
norcal6.5
Dec 7, 2014 07:04 PM
wpg6.5
Nov 19, 2014 04:56 PM
