Transfer case output / driveshaft...
Old Mar 21, 2012 | 09:09 AM
Red Mega's Avatar
Default Transfer case output / driveshaft...
Crawled under the truck while doing some maintenance this weekend and noticed that the dust cover at the transfer case output is cracked. Looks like it just got a little old and dry. Is this an issue? Looks like it would be rather difficult to replace due to the vibration dampner and yoke. Should I just goop some rtv on it to help keep it somewhat sealed, or let it continue to degrade? Can it be replaced? Any info would be helpful. Thanks!
Old Mar 21, 2012 | 05:26 PM
Sudia247's Avatar
If it is leaking, Id dab some RTV on it, but indefinably plan on replacing the seal. I bought one for a smaller 241 t-case a while back, it was around $25 for that thing, it might be a little more since the 271/273 is a bigger seal, but definitely replace it if you have the time.
Old Mar 21, 2012 | 07:48 PM
Red Mega's Avatar
It's not the rear seal on the transfer case it is the dust cover for the rear seal where the yoke goes to the driveshaft. If it was leaking I would have to replace the rear seal, but I'm not sure how vital this dust cover/seal is? Thanks for the reply!!
russellflemister
Apr 12, 2015 05:34 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
miked2805
Oct 19, 2014 11:02 PM
steves2500diesel
Oct 14, 2014 05:36 PM
