weird issue....
Old Mar 21, 2012 | 01:47 AM
jdbigblue12v's Avatar
Default weird issue....
this started after i installed my HID head lights. when i let my truck sit for more than 10-15 minutes i start it and pull the head light switch and every light on the entire dash flashes and goes away. the check engine light comes on, seat belt light, water in fuel light, brake light, wait to start and abe also low fuel light flash on.... what could cause this??
Old Mar 21, 2012 | 12:58 PM
Pacman's Avatar
Hmmm almost sounds like when you turn the lights on because the HIDS drawn so much power to start it's bringing the battery voltage down so low that the PCM thinks you shut the key off. And then once the HIDS are on the voltage comes back up and the PCM thinks the trucks running again and goes through the normal process of turning the dummy lights on and off like it normally does when you first start the truck. My guess anyways
Old Mar 21, 2012 | 01:30 PM
ya i kinda had the same feeling so ill look further into that theory and let you know what happens
pcredneck03
Mar 22, 2015 05:51 PM
norcal6.5
Dec 7, 2014 07:04 PM
Adam65
Nov 22, 2014 11:58 PM
Oct 23, 2014 08:10 AM
Oct 8, 2014 08:10 AM
