Sanden oil and freon?
Old Mar 20, 2012 | 04:27 PM
artieb's Avatar
Default Sanden oil and freon?
How much freon does the 94 Dodge Cummins hold? And I have Ester oil, would this be a good choice, and how much oil? Thanks, Artie
Old Mar 20, 2012 | 07:19 PM
wildbill's Avatar
Refrigerant is the more acceptable term, as freon was tied to R12. Not sure on the amount, but the oil does matter. Need to find out what compressor is on the truck.
Old Mar 20, 2012 | 08:22 PM
artieb's Avatar
Sanden SD7H15
Old Mar 20, 2012 | 10:49 PM
tiremann9669's Avatar
I was told to use pag oil
Old Mar 20, 2012 | 10:58 PM
mysterync's Avatar
Pag 46. What all are you replacing? Dryer and office tube? Compressor too?
Sent from my DROID BIONIC using Tapatalk
Old Mar 21, 2012 | 09:21 AM
Eddiebuntain's Avatar
Ester oil is for York style compressors,look kind of like lawnmower engines. Sanden compressors require pag oil.
Old Mar 21, 2012 | 07:09 PM
artieb's Avatar
well... It's the Sanden compressor, and it's plummbed into a 01 F350 with the Cummins spinning the compressor. This has been the worst part of the conversion! And it's last on my punch list, besides some soundproofing....
Old Mar 21, 2012 | 11:56 PM
pukie370's Avatar
what freon are you using? the oil needs to be for what freon you use. some oil will not migrate with wrong freon.
Old Mar 22, 2012 | 06:00 AM
artieb's Avatar
R134a, and I will be replacing the Ford's condenser, dryer, and the Cummins compressor was on my donor trucks engine. The compressor sounds ok and is free, and the oil was clean, I didn't remove the compressor so I don't know if the system worked, or how much oil was lost? Thanks for the replies! Artie
Old Mar 22, 2012 | 09:17 PM
You lose oil when you change condenser as well, I'd just evacuate everything and start with the correct amount that way you know you have enough in it.
