any dana 71 locker options?
Old Mar 20, 2012 | 12:31 PM
Rusty89Cummins's Avatar
Default any dana 71 locker options?
Anyone know what kind of locker options there are out there for the dana 71 axles? im tired of having no traction with the open carrior and would like to be able to have a better take off from a stop instead of spinning tire. worse case ill have to get a set of different axles i think but id like to work with what i have cuz i think i can get better fuel mileage with the 3.07 gears that are in the dana 71 axles. i dont have any experience with working on axles so any help would be great. thanks .
Old Mar 20, 2012 | 02:58 PM
That93Guy's Avatar
I believe the rear is a Dana M70 and if im right there are Detroit, ARB, powertrax, and some other options... Depends on whether you want an air or electric selectable or one that goes in and out whenever it feels like it (supposedly when you get on the pedal I believe is when they're suppsoed to engage). ARB only makes air selectable lockers and I don't know that there's anyone that would disagree with them being the best in the business, but Detroit (Eaton) also has a substantial reputation... There are also always posi lockers and limited slips... I'd start with a simple google search of "Dana 70 locker" or something. When buying one you have to make sure you buy one that will fit your gear ratio on your Ring and Pinion. Different R&P gear ratios sometimes require different carriers. Also some lockers have more splines for heavier axle shafts and unless you want to replace shafts, make sure you get one that will fit your shafts.
Old Mar 20, 2012 | 07:49 PM
hmm alright. guess i got some reading up to do about it,. thanks for the imput.
scrnnmssuck
For Sale
Mar 20, 2015 11:55 AM
Mar 10, 2015 06:00 PM
gyayo2012
Nov 15, 2014 08:11 PM
Resolute_Welding
94-98 7.3L Performance
Oct 21, 2014 08:22 AM
JJ Diesel
Oct 6, 2014 11:21 PM
