Cause of High Idle?
Old Mar 20, 2012 | 08:57 AM
dakattack's Avatar
Default Cause of High Idle?
I am a relatively new diesel owner of a relatively stock 02 24 valve 4x4 with a 6spd manual. The only mods are a hybrid turbo with a slightly bigger spool and 4 inch exhaust. Lately, after some freeway driving the idle goes from 850 to 1200. Are there some common reasons for this?
Loren
Old Mar 20, 2012 | 09:41 AM
RAW's Avatar
RAW
Is it surging between the RPM's you specified, or just occasionally going up to 1200 and staying there?
Old Mar 21, 2012 | 10:15 PM
dakattack's Avatar
In as little as 1 hour drive the idle rpm can creep up to 1200 and stay there. I turned the ignition off for 60 seconds and it goes back down to 850. I previously endured the surge and barely limped it to the shop. That time it was a camshaft position sensor which they replaced. I am not sure if this is the same thing again or not...How can you tell?
Loren
Old Mar 27, 2012 | 03:41 PM
dakattack's Avatar
Default More updates and request for input
Today the idle crept up to 1000 on the way to work. I shut it down for 30 seconds and back to normal... Then almost home about 30 miles into the trip, I noted 1300 rpm. I thought WOW that is pretty high. 2 blocks from the light, the truck goes into limp mode and has very little power and throws an engine code. I turned it off again and was able to drive it home normally with code still displayed. The tach isn't jumping around and the problem is only evident when I come to a stop light or when it gets so high that the computer feels the need to take control.
Loren
Old Apr 30, 2012 | 11:49 PM
dakattack's Avatar
It ended up being the pedal position sensor. Can be had on line for fairly cheap...
Old May 1, 2012 | 12:27 AM
Look into the Timbo Apps. Under $200 I believe
john grossman
10
Jan 12, 2019 08:58 PM
robbyS
Apr 16, 2015 02:22 PM
CumminsCoalRoller24/7
Feb 21, 2015 10:44 PM
robbyS
13
Dec 20, 2014 04:25 PM
jmerriman17
Nov 21, 2014 04:38 PM
