starting problem
Old Mar 19, 2012 | 06:34 PM
lexa111's Avatar
Default starting problem
I have an 06 cummins. The truck runs very well. It has about 74,000 miles on it. Got it in early feb of this year. For the first 2 weeks did not any problem starting. One day it started acting funny. I will turn the key to let the glow plugs heat up. When the light goes out I turn the key and it will start to crank. Heres where it gets weird. Sometimes it will start right up like is should. About 1 second or so. Other times I will let it crank for about 5 seconds and nothing. I will recycle the power and start the whole process over again. Then it will start up just fine. I can here the pump working everytime. Since then I have replaced the fuel filter. I have some ideas on what it might be. But want to get a little advice before I start chucking money at it. Thanks for the help.
Old Mar 19, 2012 | 07:38 PM
Rob_wells06's Avatar
is it really cold where you live? do you have a fuel pressure gauge? if so whats it saying during start up? also just a fyi not trying to be a dick cummins doesn't use glow plugs, the have grid heaters.
also do you have any mods, what are they. it would help if you fill in your sig.
Old Mar 19, 2012 | 07:47 PM
lexa111's Avatar
No. I live in NM. I forgot to mention it before but it will also do it after its at running temp. I can shut it down and 5 min later it will do it again. I have a straight pipe on it. Thats it right now. deployed before I could do anything else to it. But it was doing it before and after that. I do not have a pressure gauge on it so i dont know. And thanks for the info about the grid heater.
Old Mar 19, 2012 | 08:17 PM
i'd take it to the dealer and have them check for codes. maybe a bad grid heater relay. or a fuel issue.
Old Mar 20, 2012 | 07:18 PM
lexa111's Avatar
I have a code reader and there are no codes popped. I will check all the other stuff you said. Thanks.
Old Mar 21, 2012 | 12:28 AM
no problem. you might still wanna take it there. tell to check injectors, fuel pressure all that kind of stuff. i might be dead wrong but it kinda sounds like some type of fuel problem.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Jmohr52
Nov 2, 2014 08:55 PM
