Squeaking After New Wheel & Tires Upgrade
Old Mar 19, 2012 | 03:02 PM
EggosBrother's Avatar
Default Squeaking After New Wheel & Tires Upgrade
Ok, so i got a set of 305's off of my buddy that is selling his '01. Set of 305 Mud Terrain's, 50%-60% tread with offset alluminum wheels for $400. anyways, i need to level it to get rid of some rubbing during tighter turns. So my issue is, at low speed 0-15 mph i can hear a chirp out of my left front that sounds like something rubbing at some point during the tire/wheel's revolution. I cant find what is rubbing or causing this. The wheel is seated tight and flat, there is clearance to the caliper. (17" Wheel) for the life of me i cannot find it. Did not happen until after about 50 miles after i put them on the truck. Any ideas?
Old Mar 19, 2012 | 03:16 PM
lunk's Avatar
how are your brake pads might be the sqwuel tab letting you know your brakes need to be replaced
Old Mar 19, 2012 | 03:25 PM
i checked them when i had wheels off and they are good to go. Its not a high pitch like a squealer, its more of a rubbing/contact of some sort
Old Mar 19, 2012 | 06:08 PM
baddodges's Avatar
Could the offset be causing the tires to rub on any brake lines.
Old Mar 19, 2012 | 09:18 PM
tiremann9669's Avatar
Axle joint will squeak.
Old Mar 19, 2012 | 09:43 PM
empty wallet's Avatar
Did you jack truck up with wheels mounted and wiggle them in and out? Could be the start of a hub-gone-bad... thatd be that "rubbing" sound you describe, eventually it will grind.
Old Mar 20, 2012 | 08:07 AM
i'm going to jack it back up tonight and pull and wiggle, probably take them back off until i get leveling kit and see if i still have issue w/ stock wheels back on it. i checked clearances of everything when i put them on and saw no issues, they came off of a truck identical to mine other than the 2" leveling spacer and he had no issues. Its always somethin, haha
Old Mar 20, 2012 | 12:42 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Did your buddy have any issues with the tires squeaking? Or was it just when they were installed on your truck?
cutthroatxxx
Jun 22, 2015 10:16 PM
6.5dieselman
Feb 26, 2015 04:45 PM
D-350 dually
9
Feb 11, 2015 12:37 AM
Jan 20, 2015 03:01 AM
Nov 20, 2014 11:20 AM
