hello
Old Mar 18, 2012 | 01:47 PM
Michael Dowdle's Avatar
Default hello
im new here, and have a 93 cummins with some issues. i dont know a lot about diesels, and this is my first one.
Old Mar 18, 2012 | 07:08 PM
Rusty89Cummins's Avatar
what are your issues with it?
Old Mar 20, 2012 | 12:52 AM
12vChapa's Avatar
Old Mar 20, 2012 | 11:13 AM
when its in park or neutral it smokes white and back fires at high rpms, but when its moving i can floor it and it will smoke black and not back fire. also it starts strong sometimes, but other times it starts really weak
Old Mar 20, 2012 | 11:42 AM
you could be getting air into the lines or possible plugged fuel filter. check fuel lines from tank to the lift pump and check injector lines and such for a possible pin hole leak.
Old Mar 20, 2012 | 05:20 PM
ok, but if the injection lines are under pressure wouldnt the fuel come out of it? and ill check the fuel filter asap thank you
Old Mar 20, 2012 | 07:52 PM
yeah. i have a bad line and it doesnt spray out it just keeps the line wet with fuel around it.
Old Mar 21, 2012 | 09:37 PM
so my lines are good, still have not checked the fuel filter yet tho.
could it also be that my rocker arms are loose?
