Locks and windows acting up
Old Mar 17, 2012 | 11:37 AM
estill03's Avatar
Default Locks and windows acting up
My locks and window controls are on the fritz cold it be a relay? It only works half the time and I have to filled with it back and forth to get it to do that
Old Mar 17, 2012 | 01:01 PM
Eddiebuntain's Avatar
If it works when you fiddle with it the contacts in the switch are probably corroded, have you tried disassembling and cleaning the switch?
Old Mar 17, 2012 | 04:52 PM
estill03's Avatar
not yet ill give it a try, thank you . ill get back when i try it
Old Mar 20, 2012 | 12:24 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 on the switch. That would be my guess
Old Mar 28, 2012 | 06:33 AM
estill03's Avatar
x2?
Old Mar 28, 2012 | 08:32 AM
Originally Posted by estill03
x2?
Interweb/text messaging jargon for "I'll second that". They agree with me that it's probably the switch. Have you tried cleaning the contacts yet, did it fix the problem?
Old Mar 28, 2012 | 01:06 PM
Nutty Jeeps's Avatar
Same thing happened when I had my jeep and it wound up being the relay.
Old Mar 28, 2012 | 01:47 PM
Yeah, if the relay just plugs into the fusebox it could be cheap and easy to check at least. I haven't had a problem with the windows on my Dodge, so I couldn't remember if its easy to get to the relays or not.I've seen several nonfunctional power windows fixed by cleaning the switches, and the time it didn't work, the problem was a $200.00 controller. Of course this was on my own $300.00 beater. Hopefully your problem is something simple and cheap
Old Mar 29, 2012 | 04:54 AM
Devon527's Avatar
I'm having the same problem, my driver window will go down then not come up unless i wait like ten minutes, and my locks work when they want to. Hoping its just the switch
Old Mar 30, 2012 | 11:25 AM
estill03's Avatar
it seams to be the switch im gong to replase it soon and let yall know
OBSBEN
Jan 9, 2015 04:35 PM
