need helh
Old Mar 17, 2012 | 08:50 AM
Altonlee's Avatar
Default need helh
I have a 2004 f350 6.0, it starts good cold but when it warms up, when it goes to idle it dies and will not start till the temp cools off.
The code reader gives code p132b-no dtc definition found see manual, also p0603 pcm keep alive memory-kam error check pin 9.
My problem I cannot find the p132b code to read what it means. I do not have a wireing sch that shows pin nine on the pcm.
Has anyone ran into this problem?
Old Mar 17, 2012 | 10:46 AM
03Powerstroke's Avatar
sounds like an hpo leak
Old Mar 18, 2012 | 05:01 PM
Mdub707's Avatar
p132b is a turbo performance code. The KAM code is usually present if codes have been cleared or batteries disconnected at some point. Sounds like turbo probably needs a cleaning... however I agree with 03powerstroke, you're going to want to get this thing on a scanner, sounds like a high pressure oil leak somewhere. Probably the STC fitting on the HPOP. If you're doing this yourself, I'd scan it to verify first (check and record ICP desired against ICP actual, and monitor IPR duty cycle too while doing this), and replace standpipes/dummy plugs, as well as the STC fitting. Parts should run about $150 for all of that, minus the few o-rings and gaskets you may or may not need (some are said to be reusable).
