fuel limiting valve 05 3500
Old Mar 16, 2012 | 07:42 PM
Summers5.9's Avatar
Default fuel limiting valve 05 3500
Would an 05 5.9 have a fuel limiting valve? If so can it be adjusted, tweaked, or modified
Old Mar 17, 2012 | 09:29 PM
wildbill's Avatar
The pressure relief valve is there for just that. You can plug it off, but if you get too big a spike in rail pressure, it's gonna send it through your injectors, causing them to either crack, or blow the tips off. Either one, and you wind up flooding a cylinder with diesel, then it's a scored cylinder w/ the crankcase full of fuel. Blowed engine comes next.
So yes it can be modded, but without a rail pressure gauge, your taking a $10,000 chance.
Old Mar 18, 2012 | 07:15 PM
Summers5.9's Avatar
Wow! Thanks, I didn't know it would be that deep
Old Mar 18, 2012 | 09:23 PM
wildbill's Avatar
It's to be plugged ONLY when diagnosing a high pressure fuel leak.
I guess while were talking about it, any reason for the interest in modding it?
Old Apr 5, 2012 | 11:46 PM
Summers5.9's Avatar
I was just thinking of ways to kick up the fuel flow a bit, I don't want to hurt
anything though
Old Apr 6, 2012 | 08:35 AM
wildbill's Avatar
You can get a little more flow by getting a little bigger CP3. Something that flows 30% more than stock will be good enough. Not too sure if a CP3 off a 6.7 will work, but if it does, they flow a little more than the 5.9's and be a little cheaper to boot.
Old Apr 8, 2012 | 07:12 PM
Red_Rattler's Avatar
High Tech Redneck
Doesnt matter if you have more flow or not, if you dont have the programing to demand more fuel.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
12Valvepower01
Mar 30, 2015 03:41 PM
moneypitk5
Feb 12, 2015 11:01 AM
