compound with aurora 3000 and stock hx35?
Old Mar 16, 2012 | 03:03 AM
yummins's Avatar
Default compound with aurora 3000 and stock hx35?
thinking about a compound set-up for my 97. finally broke down and threw the boost gauge in. i got a boost elbo just havent put it on yet my pumps turned up about as far as i can get it. on fuel plate,gutted a.f.c,stage 2 ddp's. pushin 400 cc's of fuel. started playin 34 psi then 40 psi once and i spun a barring so now im building it. is there realy a "true" psi rating for stock head bolts? i would like to set my boost around 45-48 psi
sry for got to ask will the aurora 3000 and hx35 make a good compound setup?
Old Mar 16, 2012 | 03:51 AM
tower_ofpower's Avatar
3000 and hx35 are pretty close to the same spec, wouldn't consider them the best set of compounds. The 3000 is a very street-able single. The 3000 alone fueled right will get you extremely close to your boost goals, 40-45 psi w/o over working it.
Old Mar 17, 2012 | 12:50 AM
yummins's Avatar
thanks for the info.
any idea on how much u can push threw the auroa 3000?
