new clutch
Old Mar 14, 2012 | 09:44 PM
quinley90's Avatar
Default new clutch
i just put a new tuner on not for sure if a stock clutch will do or if i should just go ahead and get a new valair 500 hp. ideas????
oh the new tuner is a edge evo, gives 130 hp + 270 ft lbs of torque..im pushing 425 to 455 hp and 800 to 880 ft lbs
Old Mar 15, 2012 | 08:06 AM
justinram's Avatar
NEW CLUTCH!!! If you have the money, go ahead and put a new one on. I put a Smarty on last fall and tried to hold off as long as I could. Because of this, I couldn't turn the Smarty up past the half way mark and I am now in the market for new clutch. Mine is wore the hell out. You can do like me if you don't have the money but, I would suggest to go ahead and do it if you can. You will have to change it out eventually.
Old Mar 15, 2012 | 06:13 PM
mikej's Avatar
put the duel disk in now if you plan on 600 hp or more or your wasting time and money
Old Mar 15, 2012 | 07:39 PM
quinley90's Avatar
im not going to go over 500 hp due to its used on the farm and i dont wanna risk burning it up while pulling heavy
im just gonna go with a valair 500 hp 1000ft lbs clutch single disk, prolly wont go over 475 hp thats plenty for my use
Old Mar 17, 2012 | 11:30 PM
Stick with a Valair Dual Disc Kit
Luke
Old Mar 18, 2012 | 12:48 AM
Will that clutch hold 1000tq+? A diesel making 500hp is going to make well over 900 torque.
If you want to advertise here you need to become a paid sponser.
What's the plate load? What material is the clutch disc?
Luke
Old Mar 18, 2012 | 09:30 AM
InMotion Clutch's Avatar
Hello Luke, we will definitely be contacting the administrators to request the information on becoming a paying Sponsor of Diesel Bombers.
Regarding the product, the plate load on our HD Pressure Plate is over 3400LB. The friction material on the Stage 3 CompSeries is a Woven Steel Back Organic compound, centered on racing dual spring disc, which is rated to a 500HP / 900LB.Torque. If you expect to reach the 400+, low 500HP then I would recommend upgrading to a Stage 4 DominatorSeries, of course this all depends on the usage of the truck. The Stage 4 has the same HD Pressure Plate but with a Full Ceramic friction material clutch disc.!
Thanks! Good Luck!
Last edited by Deezel Stink3r; Mar 27, 2012 at 06:25 AM. Reason: No need for further information
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
lmshowalter
5.9L 24V Performance
Jul 16, 2015 06:39 PM
Dozey
Mar 5, 2015 01:49 PM
Wyocumins
Oct 19, 2014 09:34 PM
