head gasket
Old Mar 14, 2012 | 06:22 PM
chadcycle 2500's Avatar
Default head gasket
My 01 stared to use antifreeze last week.No external leaks,engine oil clean,trans oil clean,nothing in the heaterbox area,or comming from the various heater ducts. I put a pressure pump on the radiator,gauge would drop a bit with the engine warm. So I removed the head to find it had been off before. The gasket looked pretty good but the deck surface had pretty good indentations anywhere the steel firering contacted it.I took it whereI used to work at an engine rebuilding shop,so a total rebuild on the head has commenced,guides,all new,allnew exhaust valves, pressure test,planeing,setting valve depth arp head studs,etc. As usual I have to clean up from someone elses lack of prep or not doing it right. I do have a question,do I have to do a bleeding procesess on the injectors or just connect & run it?
Old Mar 14, 2012 | 06:30 PM
RAW's Avatar
RAW
If you have a strong injection pump, just bleed the fuel to it and try a few cranks that way. Otherwise just crack the lines at the head until fuel comes squirting out, then tighten them up.
Old Mar 14, 2012 | 09:00 PM
01quadcab's Avatar
so was the head o-ringed only a grove cut in the head, or was it fire ringed grove cut into both head and block? Does it have studs? The head probably needed a retorque.
Old Mar 15, 2012 | 05:01 AM
No, this was a" inprint" in the head,This should of been planed when it happened the first time it's a wonder it lasted this long,I did order ARP head studs,I'm not going to bigger turbo,huge inject this I belive I should be ok with a quality stock repair. RA Williams thanks!
Old Mar 16, 2012 | 06:11 PM
The headwork is done, waiting for head studs be here this Tues. All new guides,new exhaust valves 1 new intake valve,Planed .012" Took quite a while to grind the seats to achieve the correct depth. Going to do a good detail clean on engine & compartment & some detail painting on things,make it purdy!!
Old Mar 22, 2012 | 06:37 PM
It's Done!! 60 mi on it,so far so good. Engine sounds quieter,smoother,not sure what exactly did thisnever checked the adjustment, anyway its much better,looks much nicer also!!
Adam65
Jan 9, 2015 11:50 PM
Diesel Addict
Price Quote - Request A Price
Dec 10, 2014 06:52 PM
turbodiesel123
6.2L & 6.5L Performance
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
1994cummims
9
Oct 15, 2014 11:37 AM
