Full Auto Setup From 93 D250 adapter, starter, flex plate, TC, 47RH, and trans yoke
Old Mar 13, 2012 | 09:19 PM
pewder's Avatar
Default Full Auto Setup From 93 D250 adapter, starter, flex plate, TC, 47RH, and trans yoke
Have the full auto setup I am selling from the 93 2wd I am parting out.
This is all the parts to bolt a stock 47RH behind any 4b or 6b motor.
All the parts are included as follows,
Adapter
Starter
Flex Plate
Torque Converter
The complete 47RH trans
Trans Yoke
Speed Sensor is also on it(which is brand new, didn't fix the speedo problem in the truck)
Trans is in working order, pulled to sell since I have a 5 speed for my swap. Overdrive was working fine, but had it set on a switch and had the computer bypassed. If you would like the computer and the tps sensor the hook it all up like stock then I will include that also.
Give me $600 plus the shipping and everything is yours. This would be a full setup, perfect for using behind a 4b in any swap.
PM me with any other questions.
Would trade for a 241DHD Transfer Case or a good set of 38" offroad tires
Old Mar 16, 2012 | 04:18 PM
schu1gar's Avatar
You say working order. Good working order? Worth sticking in an '89 without going through it?
Thanks,
Gary
Old Mar 18, 2012 | 01:35 PM
Gas's Avatar
Gas
Wasnt the stock auto a non-lockup A518?
