Big psi turbo idea
Old Mar 12, 2012 | 10:21 PM
holset cummins's Avatar
Default Big psi turbo idea
hey guys, i was thinking and what if you took an aurora 5000 and put it on an exhaust manifold and once the exhaust went through the 5000, it would than break up into two different pipes and each one would go into a hx35. once it went through those two turbos, they would each have a single 4" exhaust leading back to the two stacks in the bed of the truck(like dual exhaust).the two hx35's would flow into the 5000 and than through the intercooler and so on.So tell me what you think and what i could do to improve this.
Old Mar 12, 2012 | 11:01 PM
Benjamin's Avatar
Bombardier
the positioning of the turbo's are backwards. the exhaust goes through the smaller turbo(s) first and then into the bigger one and out to the stacks, the air goes into the bigger turbo first from the air filter and thenout and into the smaller turbo and out and into the intercooler.....
Old Mar 12, 2012 | 11:16 PM
cummin_un_glued's Avatar
FormerVendor
actually benji he has the idea correct for a triple setup just the sizing is off a bit. in triples the secondary charger is actually the same size or larger then the individual primary turbos but since there are two of them they flow more then the single will. if you were using a A5k (71mm) for your secondary then you would be looking at running 62mm-71mm primarys not 57mm hx35s
the set i'm building is a 75mm secondary with a pair of 71mm primarys (195lb per min total which is more then a S510 95mm)
my advice for holset would be for a street truck a 66mm secondary with a pair of 63mm primarys...for just the turbos this set would come in around $2000 and that set is capable of 1000hp on fuel and still be daily driven
one thing to remember tho when you do a compound set the secondary spools slower then it would if it were a single so basicly you want to stay with a secondary that you know you can spool easily not something like a A5k that is laggy enough as a single because it will be that much worse in a compound set. the faster you can spool the secondary the faster the drive pressure will come up to spool the primary stage. then once the primary stage is spooled the secondary is just there to get the pressure ratio needed. that is also why you dont want to go huge with the secondary because the harder you drive the secondary the higher the pressure ratio and overall boost.
but remember there comes a point when you can get too much of a good thing
Old Mar 13, 2012 | 10:22 AM
J-Pipes's Avatar
How bout a 64mm and and pair of Hx35's?
Sent from my PG86100 using Tapatalk
Old Mar 13, 2012 | 11:45 AM
FormerVendor
Would work but the 35s are not the best choice for the primary stage. I would look more at a pair of 60mm s300 box units for that setup and new those turbos are less then 650 each. But you would likly get the same result with a s480. I will have to look at some maps to see for sure.
Sent with my DROID RAZR in one hand and 14,400 volts in the other
Old Mar 13, 2012 | 01:14 PM
FormerVendor
Ok i found some maps best i can tell on my phone these are the flow ratings i found. Anybody can correct me if these are wrong.
Hx35 - 60lb per min
S360 - 70lb
S364 - 75lb
S475 - 100lb
S480 - 120lb
S510 - 145lb
So with a 64 secondary and 60s primary you get +-140lb which would be more like running a 95mm 510 for the primary where 35s would only be 120 or the same as a 480
There really is no advantage to doing small triples because you can get the same flow with a single primary
Make sense?
Old Mar 13, 2012 | 03:14 PM
J-Pipes's Avatar
Seems to, just made me think, I'm getting a 64 off a buddy cheap, and he still has his old Hx35, could probably get it real cheap too, throw my 35 on there too, and I'd have a real conversation starter!
Old Mar 13, 2012 | 06:32 PM
FormerVendor
i just dont see it being worth it when a 80 would do the same thing and spool faster....think about this the combined weight of the pair of 65mm turbines in the 35s compaired to the weight of a single 88mm turbine.....
like i was saying before...i dont see small triple sets working all that well
you could put a S475 under the 64 and they only run around $750
there was a guy on compd that done triple 35s and in the end he decided he would have been just as well off with a single 66mm for his application
Old Mar 13, 2012 | 08:22 PM
thanks for all the feedback. the main reason i got this idea is so that you could make big boost like in the 80 or 100 range without spending 4 grand on a compound set up.
Old Mar 13, 2012 | 10:53 PM
FormerVendor
a S363 over S480 will yeild you 80psi with enough fuel and for just the chargers you lookin under $2000
my pick for a street driver triple setup would be the S363 over S360s
