Priority A Preventive Maintenance
Old Mar 12, 2012 | 09:42 PM
wildbill's Avatar
help Priority A Preventive Maintenance
This will be the fuel filter and fuel bowl. If you can get your hands on a Baldwin PF7977, install one. It's 5 micron, yes a tad short of 2, but it's better than the stock filter (10 mic) or a FLEETGUARD FS19856 (7 mic), or the Wix 33585XE (7 mic). Change it every 3,000 miles, not every 5K or 10K. This will make darn sure it's not so full of crap, it escapes past it, sandblasting the injectors. On top of the filter, draining the filter bowl 15 minutes AFTER every fill up will keep water from accumulating and being sent through the injectors.
Old Jun 5, 2012 | 04:45 PM
jmklbv's Avatar
dammit! just spent $29 on the fleetguard from NAPA!!
Old Aug 4, 2012 | 09:05 PM
smokeshack's Avatar
Hahaha i did too. just replaced it today as well
Old Oct 12, 2012 | 12:24 AM
Stevenlittle69's Avatar
went through a case of baldwins my buddy "got" from work, and now using wix, but where is the best place to order the baldwin filters??
Old Oct 15, 2012 | 12:32 AM
Old Oct 21, 2012 | 06:35 PM
mgtexas's Avatar
https://www.dieselpowerproducts.com/
I noticed that they also have an AFE with a 3 micron rating.
Mike
Old Nov 2, 2012 | 02:46 PM
Badazdads' 5.9's Avatar
Default Just bought
Ok My second diesel First winter for this truck
what are the best winter fluids and filters Michigan
Also I need to get the part number for the block heater core
as well heater grid to replace the delete If anyone can help
Old Jan 20, 2013 | 04:11 PM
Rufneckj09's Avatar
Alligator performance has an adapter where you can use a CAT screw on filter that's 2 microns and the filters are only 20$
Old Jun 6, 2013 | 09:01 PM
codyawise's Avatar
Is it really necessary to drain the filter bowl every fill up?
Old Aug 19, 2013 | 07:33 PM
dlbraly's Avatar
Default Where?
Where did you buy yours from?
