ready to do HG and studs, part#s
I am about to do HG and studs on my sisters truck, they are on tight budget but I think I can get it done for under $1500 in parts, machine work I can get done for free. For some reason I thought there was a sticky with part numbers but I'm not seeing it. I have seen some OEM HG kits with new standpipes?? are these only available through international? Looked at Tousley Ford's site but kinda hard to find what I am looking for, couldn't even find the oil cooler rebuild kit. So here is my list.. Truck is an 05 and already has the new stc fitting on it
2 head gaskets OEm
2 stand pipes if not included with HG
Dummy plugs
Oil cooler rbld kit
ARP studs
Injector Oring kit
udated fuel spring
OIl change and filter
Coolant, I'm using the Ford gold, never had an issue with it in my truck
turbo mounting kit
I have all other topend gaskets already,
Did I mis anything? thanks.
2 head gaskets OEm
Dummy plugs
Oil cooler rbld kit
ARP studs
Injector Oring kit
udated fuel spring
turbo mounting kit
2 head gaskets OEm (do you need 18mm or 20mm?)
2 stand pipes if not included with HG (I believe if you buy the FULL kit it has them, just get the gaskets by themselves)
Dummy plugs Stand pipe/dummy plug kit:6E7Z-9A332-B
Oil cooler rbld kit 3C3Z-6A642-CA
ARP studs (check with a vendor, should be around $400 or a hair over)
Injector Oring kit (I just bought an $80 top end gasket kit from Victor Reinz on ebay for my rebuild. Obviously using OEM headgaksets, but this was for injector o-rings, intake manifold gaskets, etc... came with hundreds of o-rings/gaskets)
udated fuel spring 6E7Z-9C165-B (this is spring and o-ring only)
OIl change and filter you know what to get for this I assume...
Coolant, I'm using the Ford gold, never had an issue with it in my truck (I'd probably use it too, no harm no foul, just make sure you have a coolant filter, it's cheap insurance)
turbo mounting kit Mounting kit? Just re-use the factory stuff, I've had mine off a dozen times, never had to replace anything
You'll also want the updated STC fitting kit: 4C3Z-9B246-F
What about an EGR delete?
You'll also need a bunch of distilled water, and a gallon of restore for a coolant flush (might as well at this point).
Are you doing this cab off? If so, you'll need a little trans fluid because you'll lose some when you disconnect the trans cooler.
Cool, unfortunately we will be attempting to do it cab on, my ceiling in my garage is only 10' so at most I could lift the cab 3' and if we took off wheels and lowered it as much as possible we might have 4' of seperation and I don't know if that is enough to do it or not. I have an old air powered bumper lift and a buddy has the same thing that I could use to lift cab.
I've seen that done haha. I've got one of those myself. Wouldn't be too bad if you could lift the cab outside the garage, then roll the rest of the truck in the garage and then just lower the bumper lifts and set the cab down on some 4x4 posts or something. Then you'd have the truck at normal height with no cab on it!
Yeah, just starting to tear into it and when we drained the radiator it was mostly oil, cooler let loose , gonna unbolt the ac pump and let it sit there when we remove engine so we don't create a hole in the ozone above our hous,,,,,,again
