Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
ford injectors
Old Mar 11, 2012 | 03:13 PM
jmax35's Avatar
Default ford injectors
i just replace all my injectors on my 2006 6.0l starts just fine have a engine light seems to be a little rough but when at 55 to 60 mph the engine shakes real bad let off accelerater and smoths out any suggestions wouls help
Old Mar 11, 2012 | 03:47 PM
cummin_un_glued's Avatar
FormerVendor
check your icp pressure to see if its got an oil leak
Old Mar 11, 2012 | 04:16 PM
jmax35's Avatar
what is icp pressure and where could it have a leak
Old Mar 11, 2012 | 04:27 PM
FormerVendor
Injection Control Pressure - it measures the high pressure oil pressure
your gonna need a scan tool
there are about 20 ways for a 6.0 to have a high pressure oil leak
if the pressure is low then you can do a air pressure test on the oil system
Old Mar 11, 2012 | 05:31 PM
bobfbigman's Avatar
How long has it been? they will run a little rough untill all the air is out of the system, also double check all your connections on injectors and especially on the FICM that sits on the drivers side valve cover, must hear them click or they can act funny too.
Old Mar 11, 2012 | 07:26 PM
jmax35's Avatar
the engine code is P0261 CYL 1 INJECTOR CIRCUIT LOW HOW DO I CHECK TO SEE WHAT IT IS
the engine code is P0261 CYL 1 INJECTOR CIRCUIT LOW HOW DO I CHECK TO SEE WHAT IT IS ALSO have put about 50 mile on it it starts better than it ever has
i found the number one injector connector was loose hope that fixed it motor is alot smoother will know in the morning on the way to work
Old Mar 11, 2012 | 08:02 PM
bobfbigman's Avatar
Cool, yeah a loose connector will give it a dead miss and make the truck feel like it is going to come apart, glad it was something simple..
Nov 4, 2014 01:30 PM
Oct 14, 2014 10:10 AM
Oct 14, 2014 08:40 AM
