Some questions, Fuel lift pump/vacuum/timing
Old Mar 10, 2012 | 08:05 PM
Kody's Avatar
Default Some questions, Fuel lift pump/vacuum/timing
Hello,
ive been working on getting my truck all right for a little while now, i bought a pro comp pump and i think its dieing on me, used to push about 14 psi or a little less, now it is around 5-7psi. I don't like it cause i can draw it down to 1 or 2 psi if get in it and you can feel the loss of power,
Ive got 3/8 line from the tank to the IP. I need to buy a filter to put before the next pump i get, I had a small 3/8 inline filter but it was so thin when it got cold out it would gel up badly. It also was a little restrictive. I recently took it off,
my question is what fuel pump do i get without spending $300 or more for a ppe raptor air dogg etc. I want to be able to run 15psi and not drop below 10 psi. I don't remember the flow rating on my pump but i think it is 140gph.
My other question,
I have no vacuum. I took one of the vacuum cans off and when i push the plunger it produces vacuum, I couldn't easily get the bottom one off so i couldn't test it. Im guessing the pump itself is bad, am I right? can somebody explain to me what breaks inside there? I know it is non rebuild able, im just wondering what broke? The truck was like this when i traded for it. I think i may have to replace my booster and master cylinder aswell because the brakes lose their pressure like if you had a bad brake line, All my lines are like new and none leak.
Third question,
I have been wanting to bump my timing, I guy who i talked to had a 91 and he put the head of the pump to the head of the motor. I have read this is not the best thing to do because it increases cylinder pressures by alot. He said that bumping it 1/8" and 1/4" did nothing noticeable. What is your opinion? Will a timing bump lower the egts a little? Ive got a Power stroke intercooler just have to put it in but i the mean time im looking for more power.
Thanks for any help in advance
Kody
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Gm3500
May 7, 2015 11:01 AM
RatsMC
May 4, 2015 05:25 PM
Renteria1217
Apr 16, 2015 11:38 PM
moneypitk5
Feb 12, 2015 11:01 AM
