Removing the left headlamp lens
Old Mar 9, 2012 | 03:30 PM
Marine's Avatar
Default Removing the left headlamp lens
How hard is this operation? My left lens has a bunch of condensation in it and I would like to dry it out and see if I can seal up the leaky spot.
Anybody else do this? I searched and saw someone drilling it from underneath the bumper, but I have a big winch bumper.
Any thoughts?
Thanks,
Old Mar 10, 2012 | 08:29 AM
Ed ke6bnl's Avatar
I have the same problem see what others have come up with.
Old Mar 10, 2012 | 08:48 AM
RAW's Avatar
RAW
I had one that was constantly getting wet. I'm talking like an inch of water when it rained kind of wet. Ended up being an improperly placed mesh sticker on the vent hole on the top of the assembly. I realigned the sticker, and held it in place with super glue.
Old Mar 28, 2012 | 04:28 PM
Marine's Avatar
What is the process to take the lens off the truck? I assume that is what you had to do?
Thanks!
Old Mar 28, 2012 | 05:47 PM
H.R.D's Avatar
It shouldn't be to hard to remove the lens. But to me when you do that you just have more potential to create leaks. I have a big bumper on mine as well and drilled a small hole underneath the hosing to release the water. But you will probably need to replace the entire housing unless it is something you can fix like Ryan did....just my .02 cents
Old Mar 29, 2012 | 01:14 AM
Russ Roth's Avatar
Thanks!
I just finished doing that about an hour ago. There is a small screw at the bottom side rear to undo the side marker light and it then slides forward and will come right out. There are 3 bolts holding the main housing in place. Two are on the very front, one on the top side and another down low and below the top edge of the bumper. I used a 3/8" ratchet with an extension and a wobble joint to get that one out. I think you could probably get it easier from underneath with just a plain old wrench but it was misting a bit and I didn't want to try it. The third one you can see and get to after pulling the side marker out. It's near the screw that holds it in. Then you need to pull it straight forward off a couple locating pins.
I had trouble getting the replacement back in and didn't realize why until I did some adjustments on the other lens. I had smacked a deers behind a few years ago and that was why the lens was not very good anymore. It also bent the bumper which I had straightened but not completely perfect since it was tighter to the body than the other side. Tight enough it was a bit tough to get back in but it did go. With the proper gap I think it would slide in without issue. HTH.
RR
Old Mar 29, 2012 | 10:48 AM
Marine's Avatar
Thanks Russ; I will try that. I guess the front wheel well liner has to come out first?
Old Mar 29, 2012 | 11:17 AM
RAW's Avatar
RAW
Shouldn't have to. Before I put my aftermarket bumper on, I was able to swap both headlight assemblies without removing anything other then the lights. 3 screws per side, headlight and signal light connectors, then just hold your tongue right as you remove it.
Old Mar 29, 2012 | 11:32 AM
Marine's Avatar
Ok. So where is the screw located that holds the side-marker light?
Thanks,
Old Mar 29, 2012 | 11:46 AM
RAW's Avatar
RAW
Not too sure about that one, I have never done it that way. I just removed 3 screws per side, and the whole assembly came out.
