Spare Tire Removal
Old Feb 3, 2008 | 11:34 AM
Longhorn's Avatar
Default Spare Tire Removal
Hey guys,
Im out in the field with another guy and he has a 2008 Silverado 1/2 ton. He has a flat tire and we have tried everything but cannot get the spare tire to drop...
We have made sure the rod is lined up, but there is a spring loaded deal under the tire and we can tell if there is anything that has to be done to it, but just turning the winch rod is not working....
Any suggestions...-27C and tired of laying on my back under it!!
Thanks
Old Feb 3, 2008 | 11:49 AM
Whit's Avatar
Site Mascot
this must be a Chevy thing.....look in the operators manual to see what it says??????
Old Feb 3, 2008 | 11:54 AM
Longhorn's Avatar
Yeah...thought of that but he left it at home...was studying about the new truck last night...we are about 2.5 hours from the book right now...
Old Feb 3, 2008 | 11:55 AM
bow2no1's Avatar
some times rust builds up and make them sticky.
did you try laying on yer back and kicking it? try to shock it loose.
it's probably just stuck a bit.
Old Feb 3, 2008 | 12:19 PM
Longhorn's Avatar
The truck is about 6 days old, not rusty and yea Ive kicked the poop out of it!!
Old Feb 3, 2008 | 12:22 PM
Whit's Avatar
Site Mascot
I dunno......sounds like the winch rod is turning but it aint engauged???
put the turn handle in then see if ya hafta push it in harder to engauge it???
Old Feb 3, 2008 | 01:51 PM
2500HeavyDuty's Avatar
Make sure that the rod is all the way in and its in the pilot hole. it should lower down when it is properly engaged, and make sure that you are using the right tip too
Old Feb 3, 2008 | 02:02 PM
DangerousDuramax's Avatar
Brad, like everyone said, check and make sure the rod is pushed at the way in. There is a plastic guide sleeve that the rod initially engages which will turn. Push the rod a little further to engage the gear drive.
Old Feb 4, 2008 | 08:59 AM
Nitelord's Avatar
?? any luck?
Old Feb 4, 2008 | 04:03 PM
Rttoys's Avatar
You only use 2 rods, not all 3. The larger square end goes into the tire hoist, the lug wrench get attached to the smaller square end. Then rotate counter-clock wise.
01stroker7.3
Sep 24, 2015 07:46 PM
old chevy
Sep 2, 2015 08:42 AM
dallasca
28
May 26, 2015 12:58 AM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
veggyoilkid
Tire, Wheel & Suspension
Nov 5, 2014 01:34 PM
