Can someone help with info about manual wastegate 2005 cummins
Old Mar 8, 2012 | 09:01 AM
Rynz HA's Avatar
Default Can someone help with info about manual wastegate 2005 cummins
I am new to the site, so I hope this is how you do it. I have a 2005 dodge with the cummins. I have had the P0243 error code for some time so I wanted to get this fixed, which ended up being out of my budget, beings I am also having the Auto tranny rebuilt, which is just a bunch of fun. Anyways I saw somewhere that I could take out the electric soleniod and put in a manual one. I sourced all of the parts and they are now on there way to my house. Is this the right thing to do? Do I need gauges? or how will I know what my boost is on my stock turbo. At first I was thinking $100.00 vs $690.00. Now I am thinking, what am I doing? I also had plans to put the smarty JR in but with the manual waste gate actuator, am I going to be able to put a mod such as that in? As for the manual actuator, I bought some hex bushing looking thing with a seal, a boost elbow, and something they called a fooler, but it looks more like a cap for harness piece than a fooler. Maybe I am the fool and it is a fooler. Can some please help, am I going down the wrong road? Thanks
Old Mar 8, 2012 | 09:42 AM
steved's Avatar
Search for "boost referencing"
I watched this done, I believe it should take a piece of vacuum hose, a boost elbow drilled/tapped into the intake horn, and a resistor to fool the ECM. Pretty simple actually, I had it done to my 04.5...you need a boost gauge to make sure you don't overboost (and to adjust the wastegate actuator) and cause a code to be thrown.
Old Mar 8, 2012 | 01:33 PM
MillerBoyzDiesel's Avatar
the cap looking peice is to plug into your factory harness where the w/g actuator used to plug in, you have to plug it in or youll have check engine light on. Its a w/g fooler not a boost fooler. The regular smarty has an option to turn off the electronic w/g controller, dont know about the jr. If you hit over 40lbs of boost, you will need to buy a boost fooler that plugs into your map sensor.
Durtyd09
Nov 11, 2015 01:43 PM
jeremiah1
Jul 17, 2015 09:06 AM
Hoochie
Jun 19, 2015 11:29 AM
TONYFERLAND
Apr 27, 2015 03:14 PM
Bigsexyhick
Diesel Engine Conversions
Mar 19, 2015 09:57 PM
