no boost
Old Mar 7, 2012 | 12:09 PM
jigga747de's Avatar
Default no boost
when driving normal i may hit 6psi and if i get on it its tops out at 18psi. cruising at 70mph it sits at 0psi. im thinking it may be the intercooler but want check everything b4 i going buying one. any ideas?
Old Mar 7, 2012 | 12:17 PM
RAW's Avatar
RAW
Need to know more about the truck in question. Any modifications?
Old Mar 7, 2012 | 08:13 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
Also, what your reading boost on? Actual gauge or a tuner/display that uses MAP data...
RA is correct, list your mods... However when my MAP started to die it said similar things for boost in my Adrenaline w/ Pulse... 3psi on freeway 22psi max...
Old Mar 8, 2012 | 10:17 AM
jigga747de's Avatar
reading is on an actual gaugue from the intake manifold mods are 4in straight exhaust edge comp box kn intake afe intake manifold super b speacial turbo
Old Mar 8, 2012 | 10:21 AM
RAW's Avatar
RAW
With those mods you should be making more then 18psi at WOT. I would be checking all hose clamps on the boost tube connectors for sure.
Maybe the boost fooling has stopped working on the Comp.
Old Mar 8, 2012 | 10:22 AM
I would start with boots on intercooler piping. Then check intercooler. Does your turbo have a wastegate? If so is it working properly? Make sure its not stuck.
Sent from my DROID3 using Tapatalk
Old Mar 9, 2012 | 09:46 AM
jigga747de's Avatar
I checked the boots and sprayed them with soapy water while the engine was running for leaks saw none if i disconnected the intercooler from the intake manifold and covered it engine at idle how long b4 it should have enough pressure to where i cant hold it there any longer
Old Mar 9, 2012 | 10:13 AM
RAW's Avatar
RAW
Have a look at this, it is much easier to test.
https://www.dieselbombers.com/dodge-...ke-system.html
Old Apr 4, 2012 | 08:24 AM
jigga747de's Avatar
Tested intercooler and boots-good tested intake manifold into motor-good wastegate-good any more ideas? thanks
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
