Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
63/68/14
Old Mar 6, 2012 | 10:39 AM
turbo2332's Avatar
Default 63/68/14
anyone running this size turbo? goods bads?
im wanting a little more but still need to use the truck as a truck
also what class would i have to run in with this turbo i havent mastered the art of turbo sizes yet.
thanks
Old Mar 6, 2012 | 02:52 PM
EasternAggie's Avatar
I've heard a lot of good about it. The 68 keeps low drive pressure like a 71 but is responsive like a 65.
Old Mar 6, 2012 | 02:56 PM
turbo2332's Avatar
wonder if its worth the $1600 swap from the super B?
Old Mar 6, 2012 | 10:11 PM
For as much fuel as your running, I would say definately, it'll flow quite a bit more air than that 57.
You couldn't run work stock class with that turbo, but you can run up to a 66mm in the 2.6 class.
Old Mar 7, 2012 | 09:14 PM
12workinprogress's Avatar
i am having a 64/68/14 turbo built to replace mine so kinda the same. I have heard good things about it. you should have plenty of fuel. turbo should be done in a week so i will have more info then.
Old Mar 8, 2012 | 07:59 AM
turbo2332's Avatar
please let me know how you like it. what turbo did you start with to have yours built?
Old Mar 8, 2012 | 09:11 AM
94 12valve's Avatar
thanks
you could run that charger the 2.5" class and up if you like, if you plan on pulling with it make sure you have a good wastegate set up. I have talked to a few people running these on there DD's and love how they spool and run.
Old Mar 8, 2012 | 10:15 AM
turbo2332's Avatar
would you recommend running a seperate wastegate off the exhaust manifold?
Old Mar 8, 2012 | 03:26 PM
94 12valve's Avatar
depends on how big your internal gates are ... if you go the cheep route and have none than for sure.
Old Mar 8, 2012 | 04:13 PM
94cummins12v's Avatar
im running an idustrial injection super 64/71/14 and love it street wise a tad laggy
