headlights on and off and fuel shut off
Old Mar 6, 2012 | 08:15 AM
fravelj's Avatar
bulb headlights on and off and fuel shut off
while im driving down the road with the headlights on for a while they will turn off for a few seconds and then back on then off and on and after a while they will stay on and then start doing it again. its only the headlights its not the parking lights, and it doesn't matter if there on high or low beam. is there a relay or something?
Also i got a fuel shutoff from a buddy and was working fine but when i put in my truck it doesnt pick up i have to get out and lift it and it will stay until i turn the truck off. my cus said to just replace the batterys but thats expensive is there something else i can check first?
Old Mar 6, 2012 | 11:10 AM
1AMatt's Avatar
Site Sponsor - 1aauto
I would guess its the switch itself, or the wiring. Thats typically the culprit in these trucks when they have headlight problems
Old Mar 7, 2012 | 07:37 AM
twinstang's Avatar
Check to make sure you have good grounds on your truck also
Old Mar 7, 2012 | 08:39 PM
fravelj's Avatar
well if it was a ground they would go on and off if i was on a bumpy road or any kinda of jaring they would flicker but they dont it dont matter if im going down road or sittin still. i did check a ground wire that was ground to the finder than ran to the driverside headlight but i didnt see one on the passenger.
Old Mar 8, 2012 | 06:56 PM
smoking12valve's Avatar
its the light switch itself. the one you pull out to turn your lights on. this happened on my truck. its a $80 dollar part. super easy to install though.
Old Mar 9, 2012 | 10:47 AM
1AMatt's Avatar
They are super easy to put in! Not super easy on the wallet tho
Old Mar 10, 2012 | 01:49 PM
fravelj's Avatar
alright i noticed they tend to go on and off more when i have them in high beam is it still the switch?
Old Jun 30, 2012 | 03:47 PM
fravelj's Avatar
thanks yall it was the switch
