banks Turbo. how do i get oil pressure down before turbo
Old Mar 4, 2012 | 01:20 PM
6.9idimonster's Avatar
Default banks Turbo. how do i get oil pressure down before turbo
Hey yall im new to any of theses sights. ive been a diesel mechanic for awhile and use the hell out of this site so figured i should join. ok here we go. i have a 1984 6.9 diesel. just put a banks t04b on my truck. i didnt get a kit. just the turbo. so i made a y pipe and a down pipe. hooked up an oil line and relocated the OPS and installed a t in the line to go to turbo. i think im puttin way to much oil to the turbo beings im blowing oil out of the stacks. i understand that the turbo seals might be bad, but the amount of oil is a little much for just bad seals, and i am rebuilding it with a major rebuild kit as soon as i find one that dosnt come from china. any suggestions. also i really want a 3 gauge pillar pod. Tan. does anyone know where i can get one?
Old Mar 4, 2012 | 05:16 PM
4x4manonbroke's Avatar
put a inline regulator or possibly use a smaller size feed line..... maybe like jettin a carb, maybe a smaller feed line will help with volume... not just pressure..
Old Mar 5, 2012 | 12:33 AM
91dirtydiesel's Avatar
How is the turbo oil drain set up?
Old Mar 5, 2012 | 10:28 AM
right now its set up to feed into the valley pan. but the oil just shoots back out of that to. and the line for the return is a little over half inch so i dont think its creating extra pressure and i knew about the fact its just a gravity feed return so u want a big return line. and i did go down to my local international dealer (i actually worked there for a year or so as a mechanic so they always hook me up) and got a line made up and it could possibly be to big. but from what i understand and could be very wrong but those turbos are only supposed to get around 45psi of oil. im not 100% sure what my engine is puttin out but i would hope it would be more then that.
Old Mar 5, 2012 | 03:36 PM
45 psi is good.... mine just pegged out the damn factory gauge....so I have no numbers to contribute to this one.... but 45 is not bad at opp. temp...... go I gotta go get a manual gauge so I can know..... 45 psi shouldn't be too much... unless the seals are shot....then it would be too much pressure..
Old Mar 5, 2012 | 04:00 PM
With my setup NA I ran 20psi warm idle and when turboed at the end of a 2ft long 1/4" braided stainless line I ran 10psi warm idle. Since you drain into valley pan did u punch holes in the little baffle underneath it? Mine would back up and leak like crazy until I punched the holes for it to drain faster.
Old Mar 5, 2012 | 07:40 PM
sounds plausible enough to me...... worth lookin in too
Old Mar 5, 2012 | 07:41 PM
45psi is max for the turbo. i still have factory gauge so im not certain that that is what its running. but the turbo at high rpm is throwing lots of oil out my stacks. and i think the turbo is getting much more then 45psi when this happens. im going to put a manuel dial gauge in before a inline shut off valve. then put another gauge after it inline before turbo so i can adjust what it is getting fed. hopefully this solves my problem. And 91dirtydiesel no i didnt do that and that is probly my problem there but i was going to remove that all together and plumb a straight pipe thru the center and weld it. shouldnt leak at all then.
Old Mar 8, 2012 | 12:37 PM
Oklahoma diesel's Avatar
When I got my kit from banks it said to punch some holes in the valley pan I would suggest that before you get a runaway.
Old Mar 8, 2012 | 08:05 PM
DieselCrawler's Avatar
the turbo is junk. oil pressure is NOT your issue.
