TPS specs
Old Mar 4, 2012 | 12:06 PM
jdchristianiii's Avatar
Default TPS specs
I have an idea I want to run with. To do this, I need to now what the factory tps voltages are. It is a 3 wire setup, so I need to know which wire is which and the voltage sweep (idle to WOT). Please help!!!
Old Mar 4, 2012 | 06:16 PM
jwirth's Avatar
5 volt supply is VT/WT, Sensor return is BK/LB, TPS is OR/DB wires
1 volt min to 3.5 volt WOT
Old Mar 5, 2012 | 08:23 AM
cumminskid92's Avatar
Just curious what is your idea. Im looking at doing something different with my TPS
Old Mar 12, 2012 | 09:34 AM
I was going to try to make my own tps, but I could find one with the correctvoltage sweep in that much of a turn. I just dash mounted the thing. Works great except it does have kickdown.
Old Mar 13, 2012 | 05:23 PM
montepig72's Avatar
I had to replace the tps on mine, and since I'm kind of a cheapo I adapted one I already had. It range was around a1vdc to 4vdc sweep. I had to set it around .7vdc at idle to get it to shift right. Any higher, and it waited too long to shift, any lower and shifted too early. I hope this helps.
burndiesel
10
Feb 7, 2023 01:15 AM
Craigdegolier
Jul 20, 2015 04:46 AM
Seann12
Jun 17, 2015 10:40 AM
Genghiscarl
Oct 27, 2014 10:19 AM
Gizmo52
Oct 1, 2014 02:13 PM
