Injectors for 450 hp.
Old Mar 4, 2012 | 10:25 AM
twinstang's Avatar
Default Injectors for 450 hp.
Would these injectors get me close to 400 hp. I know I would need more air since I only have A wh1c turbo. Just wondering if anyone has used this brand and is it a good price ?
Also wondering if they haze a lot
http://www.dieselautopower.com/produ...94-98-5x12.htm
Old Mar 4, 2012 | 10:26 AM
mysterync's Avatar
What injectors? Wh1c wont take you there
Sent from my DROID BIONIC using Tapatalk
Old Mar 4, 2012 | 10:34 AM
twinstang's Avatar
In the link it says injector nozzles is that the injectors ?
Old Mar 4, 2012 | 10:38 AM
mysterync's Avatar
Couldn't see the link in tapatalk. Those are just nozzles. With a older high mileage truck and the cost of new or reman injectors I would be buying the whole injector not just nozzles.
Old Mar 4, 2012 | 10:59 AM
twinstang's Avatar
Now I'm confussed does the injectors go in the nozzles which have bigger holes ?
Because my truck only has 85,000 miles on it which is low for a 1995 and it says 90 hp over a 160 hp pump which I have
Old Mar 4, 2012 | 11:05 AM
mysterync's Avatar
Nozzle mounts to the injector body and flows more than a factory unit. It still needs to go to a injection shop or a shop with a pop tester. Why not spend a little more and get a balanced injector you just pop in and go. I've always recommended a pop test / injector service somewhere after 100k to keep mpg up and truck running smoothly. Don't forget the truck is still 17 years old it may only have 85k but it might idled 30,000 hours
Old Mar 4, 2012 | 12:30 PM
twinstang's Avatar
Thanks, just when I think I figured stuff out I learn some more again. So if I was to buy a used set of injectors do I need to ask what nozzle it comes with ?
Old Mar 4, 2012 | 12:35 PM
Don't buy used spend the money on a good set of new injectors.
Luke
Old Mar 4, 2012 | 12:41 PM
twinstang's Avatar
Ok thanks
Old Mar 9, 2012 | 02:05 PM
jkidd's Avatar
We have injectors with nozzles already installed an pop tested. Plenty of sizes in stock.
