wh1c-3b twins
Old Mar 4, 2012 | 06:18 AM
gwhammy's Avatar
Default wh1c-3b twins
Comes with a wh1c, 3b, hot pipe, cold pipe,spring wastegate for the wh1c,compressor housing with 3 inch slip coupling welded on the housing. 900 plus shipping, pm me for pictures and I can text them.
Old Mar 4, 2012 | 02:02 PM
oil_burner's Avatar
do you have a downpipe for the 3b? pm sent....
Old Mar 4, 2012 | 03:14 PM
gwhammy's Avatar
No, I don't trust myself to build one unless it's on the truck. A down pipe is real easy to make if you reduce it to 4 inch right after the first 45 degree bend.
Old Mar 6, 2012 | 12:22 AM
03CTD4x4's Avatar
Pics?
Old Mar 6, 2012 | 05:58 AM
gwhammy's Avatar
I can text them off of my phone if you want to see them. The clamps aren't on but I have them. I do some traveling will be back and forth from shreveport,la. a couple of times soon. Looks like you are around tulsa. I'll be in memphis before I go to shreveport.
Old Mar 6, 2012 | 07:19 AM
03CTD4x4's Avatar
Txt me some pics 9184082006
Old Mar 6, 2012 | 02:58 PM
gwhammy's Avatar
I could probably make the connector and weld a 45 to it. Then all it would need is the right length pipe and another 45 on that to head back. Those connections could be made with a slip coupling.
