anti freeze smell??
Old Mar 3, 2012 | 11:30 PM
blacksmoke82's Avatar
Question anti freeze smell??
2004.5 dont overheat oe smell runnin down the highway but as soon as its under a load or workin a lil hard it gets warm an smells of anti freeze. i dont see any leaks im stumped any ideas
Old Mar 4, 2012 | 09:15 AM
Gerry R's Avatar
Default antifreeze smell
If you are smelling it in the cab it most likely is the heater core or the connection to the core I would think. That's all I can think of that could leak coolant inside the cab.
Old Mar 4, 2012 | 08:46 PM
i had steam on the drivers side under the hood once too but couldnt find any antifreeze. its fine normal driving everyday i travel about 220 miles a day the only time you smell it is under a load on a big hill but only if its working hard. im baffled guess it time to get another 12 valve an not mod it as heavy as my other one so i can get it to start in the winter
Old Mar 4, 2012 | 09:06 PM
H.R.D's Avatar
It could also be a small leak from the head gasket or the thermostat housing. I am leaning towards heat core as well. Does your heater produce "fog" when it is on?
Old Mar 7, 2012 | 06:57 PM
no heater works normal no exhaust smoke other than a little black the temp seems to stay alot closer to 200-205 on a warmer day. coult it be the water pump it looks like theres a small leak from that?
Old Mar 7, 2012 | 07:01 PM
H.R.D's Avatar
It could be leaking through the weep hole on the water pump. I think you can check them by take the belt off and turning by hand. If it is real hard to turn I believe it is shot.
I pretty sure that is how you tell.
Old Mar 8, 2012 | 09:47 AM
steved's Avatar
Look at the water pump weep hole.
Also look at the steel lines running under the exhaust manifold. There is a silicone tube that connects the steel lines, they tend to leak because the clamps get loose.
I've experienced both, and never saw a drip on the ground...
Old Oct 23, 2012 | 07:19 PM
Thunderroad2005's Avatar
What what the outcome of this? Mine ended up being heater core, what a pain. Three months later I have to do it again, bad factory core or ????
rocanater
Ford Powerstroke 08-10 6.4L
Sep 29, 2015 04:38 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
