NV4500 To NV5600
Old Feb 2, 2008 | 12:35 AM
94cummins12v's Avatar
Default NV4500 To NV5600
i was wondering what input shaft was on my 94 dodge cummins 12v i have a 5 speed nv4500HD 4x4 and was wanting to throw a nv5600 on it i was wondering if it was a 1 1/4 or a 1 3/8
Old Feb 2, 2008 | 12:57 AM
NV4500HD Specs:
* Manufactured by New Venture Gear
* Synchronizers: Carbon fiber composite
* Input shaft: 1-1/8" 10 spline (V8 version - order code DDP)
* Input shaft: 1-1/4" 10 spline (Diesel, V10 version - order code DDX)
* 4x4 Output shaft: 1-1/2" 29 spline
* Input torque rating: 460 ft-lb
* Max GVWR: 16,000 lb
* Max GCVWR: 21,000 lb
* Cast Iron Case, Weight (with oil): 250 pounds
* Fluid Capacity: 8.5 pints
o Fill level is to the bottom edge of the fill plug hole.
o These are the ONLY lubricants recommended for the NV4500:
+ 75W-90 Castrol Syntorque Synthetic
+ Mopar Manual Transmission Lubricant (PN 4637579)
+ GM Transmission oil (PN 12346191)
+ NOTE: Syntorque is NOT the same as Castrol Syntech.
+ Standard Transmission has the oil. 1-800-783-8726
+ Alternative oils?
* Drain Plug P/N: 4882280
Gear Ratio
1st 5.61
2nd 3.04
3rd 1.67
4th 1.00
5th 0.75
R
5.61*
Old Feb 2, 2008 | 04:35 PM
rbratby's Avatar
Your Nv4500 has a 1 1/4" input shaft. Early model Nv5600's also had a 1 1/4" input shaft. The 2001.5 and newer Nv5600's have the 1 3/8" shaft.
Old Feb 4, 2008 | 12:03 AM
oh ok i want to remove my nv4500 and replace it with the nv5600 also we will be putting the nv4500 in my buddys 95 2500 cummins and swaping his auto trans with my nv4500
boostkid
Jun 3, 2015 11:17 AM
dpgcummins12v
12
Apr 20, 2015 10:24 PM
SixSpeed
Jan 11, 2015 01:41 AM
CumminsMan2.0
Dec 11, 2014 04:57 AM
GreenDieselF
Nov 9, 2014 07:18 PM
