COULD SOMEONE PLEASE EXPLAIN THIS??
Old Mar 2, 2012 | 10:07 PM
65fathead's Avatar
Question COULD SOMEONE PLEASE EXPLAIN THIS??
I posted this on another forum on the site and got a few replies. Thanks for the ones who did!! I asked if smoke coming from the crank case tube and a little oil dripping out was normal? If so, how much smoke is normal? Because it pretty much pours out of my tube. At times, sitting at a stop light. It looks like my truck could possible be on fire, LOL.
Also, what causes this? The heavy smoking that is!
Thanks for ya'll's help!!!!!!
Old Mar 2, 2012 | 10:13 PM
H.R.D's Avatar
Your rings on your piston are shot. It is normal to have some blow by but what you are describing is excessive blow by. I would start thinking about doing an overhaul on the ole girl.
Old Mar 3, 2012 | 01:54 AM
RAW's Avatar
RAW
Only other reason to get that much blow by (compression blowing past the sealing surfaces) is valve stem seals. Essentially, Compression and/or combustion gases are leaking past the piston rings and/or valve stem seal and causing excessive pressure in the crankcase. Unfortunately for you, a rebuild is very close in you future. The longer you wait, the more it will cost.
Old Mar 3, 2012 | 10:10 PM
tiremann9669's Avatar
How many miles on it ?
Old Mar 3, 2012 | 10:13 PM
65fathead's Avatar
It only has 177,xxx and runs great.
Old Mar 3, 2012 | 10:21 PM
Dosn't make sense for rings to be shot at 177K unless it hasn't been maintained as far as oil level and change intervals. What are you running for oil ?
Old Mar 4, 2012 | 11:02 AM
GuyWithA24Valve's Avatar
If it has idled a lot over its life then it wouldn't be surprising that the rings are shot at 177K
Old Mar 4, 2012 | 06:33 PM
65fathead's Avatar
I'm running 15w-45 for oil. Since i've had the truck I've changed the oil every 5,500 miles or sooner. Now the truck manual says 11 qts if i can remember and my haynes manual says 10 qts. when i put 11 qts like the factory manual says, its a taste over full. Im also running lucas in the oil. Could that be doing it?
Old Mar 4, 2012 | 06:36 PM
I personally have not liked what I've seen inside an engine that had run Lucas, like big globs of tar
