Rev X and Rotella T6
Old Mar 2, 2012 | 02:12 PM
bkmac's Avatar
Default Rev X and Rotella T6
Changed out the oil and filters, both oil and fuel, today. Motorcraft oil filter and IH fuel filters. This time I went from Rotella T3 to Rotella T6 ($7.00/per Gallon cheaper at Wally World then NAPA).
First time around the block to check for leaks the truck died - figure it was just air in the system because she fired up after a little bit and has stayed running.
Since I have been have very rough running until the truck warms up I came back and added two bottles of Rev X. I may be crazy but the second time around the block the truck seemed like it had more power and quicker response and was running smoother - it may have been because it was warmed up a little. It may also be because I got all of the crap out of the fuel system. Tomorrow morning will be the real test to see if it is still running rough - fingers are crossed.
Old Mar 2, 2012 | 03:25 PM
Mdub707's Avatar
It's not that surprising actually. Bill from PHP has dyno testing of it and you'd be surprised how much power he picked up from adding Rev-X.
Bill, you should post those graphs over here too!
Old Mar 3, 2012 | 10:57 AM
bkmac's Avatar
Another convert and believer in Rev X - could not believe the difference in the truck this morning
Old Mar 4, 2012 | 05:35 AM
HeavyAssault's Avatar
Anything that needs to be added at every oil change isn't helping the real issue.
Old Mar 4, 2012 | 08:10 AM
papachuck's Avatar
It may not put new injectors in your truck, so it doesn't fix the real issue. But for most it does help. There are a lot of snakeoil type products out there, Rev-X is not one of them. I am a huge skeptic and the only reason I tried it was I got in on the free trial, It worked as claimed. For the cost, I would say try the Rev-X before you start throwing money at injectors. I am just shy of 200000mi and have replaced 2 injectors, 1 before Rev-x and 1 after.
Old Mar 4, 2012 | 08:39 AM
mysterync's Avatar
Revx is awesome. Keep it on the shelf for a reason .
Sent from my DROID BIONIC using Tapatalk
Old Mar 5, 2012 | 09:02 AM
Mdub707's Avatar
Rev-X would most likely show an improvement on the dyno even on a set of 8 new injectors.
I get what you're saying though, and you're right, it's just a band-aid.
Royals30
Aug 4, 2015 12:06 PM
