trying to find a pump shop that will bench my pump to make hp...
Old Mar 1, 2012 | 12:31 AM
jayman54's Avatar
Default trying to find a pump shop that will bench my pump to make hp...
i'm in alberta and picked up a low k 215hp p-pump and want to get it set up/benched to swap out for my tired old 175hp... i've talked to alot of pump shops and none want to do anything more than a stock setup...i'd like the get the flows raised and balanced...also should I remove the plate if i take it into a pump shop?? and its has stock dv's but i have sdx comp dv's in mine now...could i just swap them when its been setup or put them in before hand?? any advice would be great...i'm in hinton ab so BC isnt far away either...any advice would be great
Old Mar 4, 2012 | 08:44 PM
jayman54's Avatar
really no one...
Old Mar 4, 2012 | 09:44 PM
wahlstrom1's Avatar
I don't know if NADP does any actual pump work, but you could try Cummins in edmonton itself. I know when I worked in red deer we used Art at Central Diesel Injection, he's good ****.
Old Mar 5, 2012 | 07:43 AM
gwhammy's Avatar
Put 4000 while it's timing when you put it in, work the afc over.If that's not enough fuel rotate the barrels. I'm pushing 63 lbs. of boost with stock 180 injectors and a 215 pump with the mods I mentioned.
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
