propane injection water meth injection mix
Old Feb 29, 2012 | 09:48 AM
skyler1101's Avatar
Default propane injection water meth injection mix
i currently have cooling mists water meth kit and i just bought a propane injection kit here is my question can these both be mixed and used at the same time safely?? or is this a monster no no has anyone tried this?? thanks guys!
Old Feb 29, 2012 | 11:32 AM
2004LB7's Avatar
any combination can be made to work fine. too much drugs will ruin things quickly. now when you start making cocktails it gets even more tricky.
depending on how much you run the propane may counter the cooling effect of the W/M injection and your EGT may go back up.
i would say if you are going to run both then turn them back about half way then work up from there, or at least start small on the propane. i have read many people running large amounts of propane and it working fine, others are breaking stuff and burning things up. more people seem to have good luck on the W/M injection. few run both.
your cummins is a stout engine but i wouldn't push your luck
see what others say
Jason
Old Feb 29, 2012 | 03:41 PM
skyler1101's Avatar
thanks man ! it will be for a short period of time down the pulling track thats all they will be used for
Old Mar 1, 2012 | 09:05 PM
skyler1101's Avatar
no one has an answer?
Old Mar 1, 2012 | 10:13 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
sorry bud. we are not allowed to run methanol. i dont know how it reacts on the track
Old Mar 1, 2012 | 10:55 PM
skyler1101's Avatar
shoot! does anyone know if its safe to even run both at the same time at all?
Old Mar 2, 2012 | 01:06 AM
2004LB7's Avatar
there are levels that are safe and levels that are not.
i would set up the W/M injection and then slowly add the propane while watching the exhaust temp.
i dont run propane so i would wait for more replies first
Old Mar 2, 2012 | 08:50 AM
skyler1101's Avatar
ok thx
Old Mar 6, 2012 | 04:18 PM
wedge67's Avatar
have you run the propane alone? how much HP are ya gettin out of it?
is it all its cracked up to be for mileage enhancment and power?
Old Mar 6, 2012 | 04:30 PM
2004LB7's Avatar
for mileage it is a fuel replacement. what you end up doing is replacing diesel for propane. the btu's for diesel is somewhere around 140,000 and propane 91,500. you end up using more propane per mile but if you can find it much cheaper then diesel then you come out ahead. the more propane you inject the less diesel you will use and vise versa while cruising.
