Rear main seal
Old Feb 28, 2012 | 11:03 PM
CumminsKid6's Avatar
Default Rear main seal
I believe it started leaking awhile ago. But it's getting alil more under coat on my truck. But my question is can u change th rear main seal without dropping the pan or is it a full on take motor out and apart.
Old Feb 29, 2012 | 12:14 AM
H.R.D's Avatar
Rear Main Seal Install - Dodge Diesel - Diesel Truck Resource Forums
Old Feb 29, 2012 | 06:20 AM
Ok thanks. Next question is if it were leaking outta the rear main would there be oil all over my fly wheel or could it possibly leak between the engine and adapter plate
Old Feb 29, 2012 | 03:18 PM
bigdaddytex69's Avatar
When i did the rear main on my 96 it was hard to tell where it was coimng from it was pretty bad but i would bet it would be between the engine and adapter plate.
Old Feb 29, 2012 | 05:26 PM
Billy D's Avatar
Maybe that back valve cover maybe
Old Feb 29, 2012 | 07:18 PM
ricet07's Avatar
x2 there was a post awhile ago where a guy thought his rear main **** out on him and turns out it was the back valve cover.
Old Mar 1, 2012 | 11:38 AM
1AMatt's Avatar
Site Sponsor - 1aauto
The valve covers tend to leak quite a bit on these motors. Id check that first too! it would save you a TON of work
shingi
Off Roading
Sep 30, 2015 11:17 AM
yfzrunner
Sep 17, 2015 05:23 AM
Machinist
Jun 23, 2015 06:57 AM
Max713
Apr 17, 2015 01:20 AM
wildbill
Jan 31, 2015 11:14 AM
