boost conection?
Old Feb 28, 2012 | 08:04 PM
holset cummins's Avatar
Default boost conection?
hey guys, i am putting a boost gauge on my truck and i plan to tap a hole into my intake horn but i dont know what size to make the hole? i have my stock boost elbow from my turbo and i plan to use that to feed boost pressure to my gauge.Now, i am in one of those situations where i needed this to be done yeaterday so its not like i can order the right fitting unless that boost elbow wount work, then i have no choise so if you could help me out with the drill size that would be great.
Old Feb 28, 2012 | 08:12 PM
mysterync's Avatar
NBoost bolt. No drilling just take a plenum bolt out and install in its place. Much cleaner looking install .
Bit size and tap for your elbow would be size r, size q or 11/32 and 1/8th npt tap
But plumbing it this way can cause boost leaks at higher boost pressures
Sent from my DROID BIONIC using Tapatalk
Old Feb 28, 2012 | 10:29 PM
turbolag's Avatar
why not spice into the waistgate hose on the bottom of the turbo? did mine there had no issues
Old Feb 29, 2012 | 05:18 PM
yea i think i mights just use the waistgate hose. i just hope i have enough vacume line to reach
Old Feb 29, 2012 | 05:22 PM
chadcycle 2500's Avatar
I made my own boost bolt drilled out a bolt pressed in a barbed fitting works fine,but I forgot where I got the fitting from, this is not hard to make
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
