Dual Fuel Feed into my 215 pump
Old Feb 28, 2012 | 02:35 PM
M-Schuler's Avatar
Default Dual Fuel Feed into my 215 pump
I want to make a dual fuel feed for my pump.. how do i go about makin this set up?? any help would be great
Old Feb 29, 2012 | 08:37 PM
jayman54's Avatar
pull the banjo bolt and go to a hydraulic get a JIC fitting for both ends and get them to make ya a line it'll never wear out...i made mine at work with hydraulic fittings looks pretty sweet...
Old Mar 2, 2012 | 10:57 AM
CumminsKid6's Avatar
We're do u dual feed from cause as of now there is only an inlet and outlet. Feed and return. Where does the second feed come in
Old Mar 2, 2012 | 12:17 PM
turbo2332's Avatar
the front of the pump
Old Mar 3, 2012 | 11:17 AM
nasty 2005's Avatar
Why waste your time the stock pump can't pump any more fuel. install an airdog or a fass and be done with it! imho
Old Mar 4, 2012 | 05:22 PM
M-Schuler's Avatar
im going to be putting a airdog on the truck soon and then the dual feed lines so i know that im getting the most fuel i can into that pump..
Old Mar 4, 2012 | 08:38 PM
dipapadakis's Avatar
you go through the port on the front of the pump its a 10mm allen i forget the thread count on it and through your stock port if you go to parker hose its around 51st and van buren they have all the stainless hoses and fitting i just put a dual feed and a/d 200 on mine ill see if i can get a picture up it came out pretty clean i think
Old Mar 5, 2012 | 08:16 PM
94 12valve's Avatar
https://www.dieselbombers.com/5-9l-1...ed-p-pump.html
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
