Starting issues
Old Feb 27, 2012 | 10:10 AM
Blackdog3's Avatar
Default Starting issues
I have been having starting issues for a little bit of time now. I know the weather has been colder in the northeast but it hasent been horrible. I had the injection pump taken off and seal put behind and ever since then in 50 degree temps the truck carry's on like crazy. Its an 89 5.9 motor ve pump no mods, no ic.
It just cranks and cranks wanting to try to start puffing white smoke everywhere.... eventually maybe 2mins of total crank time. After it starts it smokes like crazy just sitting there for about maybe 5-8 mins. Still white smoke. Once its warmed up and going its fine. Also it will do the same thing if its been sitting for a few hours. I guess i will see what happens when the warmer temps come....
Old Feb 27, 2012 | 10:59 AM
moparbubbabt59l's Avatar
Is your grid heater cycling? And is your ksb hooked up?
Sent from my DROIDX
Old Feb 27, 2012 | 11:04 AM
Blackdog3's Avatar
^^ I forgot to mention... i dont have glow plugs. I am assuming that would be the major cause of the starting problem.
Old Feb 27, 2012 | 11:13 AM
Yea 1at gen cummins never had glow plugs..... you have a intake grid heater
Sent from my DROIDX
Old Feb 27, 2012 | 11:15 AM
Blackdog3's Avatar
Hmm well since its in a Chevy, and my motor came out of Blue Bird Bus. I am assuming this isnt here. I have to do some research i guess unless anyone can point me in a direction to go. Thanks for you help man!
Old Feb 27, 2012 | 11:29 AM
Its a 6bt right? Look under your air horn itll have two wires running out of it when its cold can you hear them click on and draw down the battery? Unless it wasnt hooked up when it was swaped.
Sent from my DROIDX
Old Feb 27, 2012 | 12:07 PM
Blackdog3's Avatar
It is a 6bt, I am going to have to look when i get the truck from my shop later. But nothing clicks on when i first initially turn they to the run position.
Old Feb 27, 2012 | 12:48 PM
http://www.dieseltruckresource.com/d...d.php?t=130793
Sent from my DROIDX
Old Feb 27, 2012 | 01:09 PM
Blackdog3's Avatar
i am 100% positive i don't have any of that.
Old Feb 27, 2012 | 01:27 PM
Then you dont have a cold start aide and thatll do what you described smoke and run rough tilll warm
Sent from my DROIDX
