max boost on non o-ringed head
Old Feb 27, 2012 | 05:35 AM
russellflemister's Avatar
Default max boost on non o-ringed head
i installed bd twins on a buddy engine i tryed to convince him to have it o-ringed but he didnt but we did install arp head studs was wondering what i should adjust the wastgate to so he dosent blow the head this is on a 2001 dodge 24v 2500 with 220k on the engine
Old Feb 27, 2012 | 08:03 AM
RAW's Avatar
RAW
I don;t think anyone can say for sure what it will hold. Headgaskets can blow at any time, for a bunch of reasons. Was the head machined before the gasket and studs? Is he going to do multiple re-torques? I'f I had to pick a number, I would say 60 PSI MAX. Then again, I'm hitting 55-57PSI with an original gasket and factory head bolts.
Old Mar 5, 2012 | 03:00 AM
head was decked only took 2 thou. off not bad i checked head with a strait edge and feeler gages and only could get the 2 under the strait edge cummins said up to 3 is fine but i had it decked anyways just to be safe but didnt have anyone at where i worked could do the o-rings but i decked the head for him for free
Old Mar 5, 2012 | 08:56 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i see trucks run with no orings on the track that dont blow head gaskets. then you have some that do. we see guys that have orings and head studs blow also but i think the install wasnt done right. flat decked head seems to be the key. i am running 60lb boost and no orings. i am thinking about having a head ported and oringed. i prob still will use new head bolts we sell. i know when brian does a head gasket repair he ALWAYS has the head decked. he ALWAYS uses cummins brand gaskets. we had a guy running in the open class with nitrous last year that run 80 lb down the track. he has no orings and has our bolts in there and no head gasket trouble. he did blow up a brand new turbo though.
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
