Injection Pump Issues Again...
Old Feb 26, 2012 | 07:17 PM
Cummins12Club's Avatar
Default Injection Pump Issues Again...
I swear no body on this forum seems to have as bad of luck with their ve pump as i do. my latest issue is my fuel shut off soleniod stuck open, no biggie, ive just been turning it off manually, decided today to put a manual pull cable on it to make life easier. so after some research got to work, i took the cross looking lever off to atatch my cable and then did so, put it all back together and the cable worked great, turned the truck on and tried to pull it to shut it off, it moved the lever back as it should but the engine did not shut off, i realized i must have the the teeth off by one or so, so took it back apart and changed the position, but for some reason the fuel shut off shaft's teeth got rounded off almost and now when i push the lever back it just spins and doesent pull the shaft back. so my issue is if this shaft is a part i can buy and if so what is its actual name? any help is good, thanks
Old Feb 26, 2012 | 09:31 PM
tower_ofpower's Avatar
Good luck finding that shaft sold separately, you sure the lever just isn't making full contact with the teeth? Like the shaft might have just been pushed in slightly? There isn't a whole lot to really grab onto spline wise. best bet would probably be to go to a pump shop and have them Oder it for you, never seen one sold separately anywhere.
Old Feb 27, 2012 | 05:25 PM
Thanks for the info, looks to be a non serviceable part but ive got it back together and it doesnt leak so im just going to leave it alone and put a fuel solenoid on and be done untill one day i p pump
Old Feb 27, 2012 | 09:40 PM
It's serviceable; had to swap it over to my new pump top. Just don't know if replacement part is available.
dwmeehan
Jan 29, 2025 12:13 PM
nelly559
Feb 17, 2015 06:49 PM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
