Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
View Poll Results: WHAT WILL YOU BE DOING
ATTENDING
83.33%
NOT ATTENDING
0%
POSSIBLY
16.67%
UNSURE
0%
Voters: 6. You may not vote on this poll
May 5th WAYNE COUNTY TRUCK AND TRACTOR PULL
Old Feb 26, 2012 | 11:34 AM
sixinarow07's Avatar
Default May 5th WAYNE COUNTY TRUCK AND TRACTOR PULL
Wayne County Truck and Tractor Pull
May 5, 2012
Wayne County Fairgrounds- Wooster, Ohio
Tractor Classes: 9am
Truck Classes: 4pm
Tractor Classes: $20 Entry Fee
Stock: 1975 and older, 4MPH speed limit, Engine must match the make of tractor, Cut tires allowed, No tires larger than 18.4“, No turbos, Judges decisions are final
Open: No tires wider than 18.4”, The “rotating clutch assembley” must surrounded 360* with minimum of 3/16” steel, ¼” aluminum, or use a SFI 4.1 or 4.2 blanket. Blanket must completely surround clutch. Two blankets may be used to accomplish this.
* ALL CLASSES MUST HAVE A MIN OF 5 COMPETING TRACTORS
1. 3500lb Stock 8. 6500lb Open
2. 4000lb Stock 9. 8500lb Stock
3. 4500lb Stock 10. 8500lb Open
4. 5500lb Stock 11. 6500lb V8 -5000 RPM Limit (Following Columbiana Co. Antique Tractor Assc. Rules)
5. 5500lb Open 12. 6500lb V8- No RPM Limit
6. 6500lb Stock 13. 16,000lb Hot farm/ Farm stock
7. 10,000lb Open
For any questions on the tractor class, call: Jim Flinn (330)-465-4397
Truck Classes: $25 Entry Fee
Evening truck classes will start at approximately 4pm
70% Payback
6200lb Street Stock Gas Truck Rules:
26”hitch(no exceptions), Must pull from Reese style hitch, No trick hitches
DOT tires only
Factory fuel injection or single barrel carburetor(No dominator carbs)
Naturally aspirated, No Nitrous, No water injection, No propane
Minimum 1’’ of suspension compression is required
Must have exhaust that exits behind cab
Current plates, registration, and valid insurance required
All trucks must be street legal, judges decisions all FINAL-No whining
Hanging weight allowed but must not exceed 60” from center of front axle
Open Gas Truck:
6200lb
26” hitch(no exceptions)
DOT tires only
Naturally aspirated, No Nitrous, No propane, No water injection
Hanging weights allowed but must not exceed 60’’ form center of front axle
Front and rear u-joint shields are required(No exceptions)
Trucks must have blow proof bell housing, scatter blanket and SFI approved clutch
Diesel trucks will follow NADM rules
6200lb Open Gas
8000lb Work Stock Diesel( Hanging weights will be allowed)
8000lb 2.6” Diesel- (Hood stacks allowed)
8000lb Super Street Diesel
8000lb Open Diesel Truck
For information on truck classes call: Brandon @ (330)-749-8947
* No alcohol will be permitted on the fairgrounds
Old Mar 5, 2012 | 06:38 PM
zeigler86's Avatar
ill be there running my ws truck!
Old Mar 7, 2012 | 05:12 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
I want to give this a shot too! Would be a good test for the new tranny! If I am not racing the Enduro @ Crash-A-Rama/CarWarz I will be there!
